Sidecar Swinger (as the Ausie's call them) Required
Postby tintop » Wed Jan 11, 2012 6:11 pm
As things are finally starting to fall into place, thought I should post this now.
I have an open chair spot on my P2 rig, that needs filling before the 1st turn at the Shannonville school. :lol: As the subject says, I'm looking for a passenger / monkey / swinger. As I'm a rookie, my preference would be for someone with some experience, and large appendages (see rookie reference :wink: ). That said, sidecar is a team sport, so learning to work together is what it's all about. So a rookie with the 2nd qualification is also an acceptable option, 'edit' or very brave female (don't want to sound sexist).
The plan is to run both Shannonville events, Mosport, & given myself, the rig, and funding holds out Quebec. I'd also consider a US event(s), but not at the expense of using funds that would get the rig to the Quebec round.
Anyone interested can reply to this thread, by PM, or email. Any & all suggestions, help, funds greatfully accepted. :)
(provisionally #939)
Re: Sidecar Swinger (as the Ausie's call them) Required
Postby tintop » Sat Feb 18, 2012 10:36 pm
So as of tonight the chair has been filled. Having finally had a chance to meet in person, 'Hopper' will be refilling the same space he once occupied. :D :D :D
Postby limy_1 » Mon Feb 20, 2012 4:05 pm
Aah, so you are the one that pried the rig from Rob Verrier.
Good luck to the both of you in the up coming season.
Roger Preston
limy_1
Postby tintop » Mon Feb 20, 2012 8:06 pm
Thanks Rodger. While it was basically all there, it's been sitting for 3+ years. So as of now it's been stripped to the frame, and the engine is on the floor. Lots of little, and a couple of big things that need attention. As I'd like to get some seat time before the Quinte TT, plans is to have it ready for the April track day.
