VM3 is 2". I have contacted Ahrma about my bike and am waiting for an answer as to where it fits..
Rick
BrianL wrote:All is good, I just did the same thing to an almost pristine TT500 which I had offers in the $2000 range.
SR500........$100
TT500........$500
18" front.....$20
Recoverd seat..$30
Time spent in garage building MidPrd Monster.......Priceless!!!!!!
autofobe wrote:I have a question, the BSA B25 is ok for this class for all years (up to year 1970)? Is this correct?
Aslo for rims, VRRA lists VM4 (2.50) and AHRMA lists VM3, how wide is VM3? And are you guys making your P1-200 AHRMA legal?
I beleive the BSA B25 goes to 1972. Why, do you have one your building?
Also I beleive a VM3 is 2.15 wide.
Brad
autofobe wrote:The t25 I beleive is the 71 oil in frame.The same frame as Peters B50.The frame handles well & the motor has better bearings & trans than the early models.Front wheel is to big & the front brake to small.A conical laced to an 18 would bolt right up.60/70 bonniville TLS is as good but not as easy to fit.A 30 mm carb & lose the muffler for a reverse cone (pipe is ok, runs inside the frame rail) These bikes were fairly light for their size.The 250 motor reved higher than 500 (about 8200 red line I think) A twin plug head is a period mod & with the pipe & biger carb they run quite well.If you raise the compression a roller starter will be in order.You will need to work on it,it's not a jap bike.I'm sure Peter would be able to tell you a lot more.
I have a b25 & a 441.I'm not sure which way to go.These bikes a very easy to work on & fairly reliable if kept maintained & not overreved.They are very torky & the 250 should hit 80mph with stock gearing.The 441 has more grunt but not much more top speed.I beleive the 250 can run in pre 65 350 & bumps to P1 200.
Brad
Users browsing this forum: No registered users and 9 guests
